Industrial Communications
Reply
Dynamic PIL simulation of 4-20ma current loop sensor
I am developing a Processor in the Loop (PIL) where I want to simulate sensors communicating via 4-20ma current loop protocol. I want to be able to dynamically (ie, under control of a computer) program the sensor value.  I see NI has a board the implements eight 4-20ma receivers.  I am looking for a device which can simulate a 4-20ma "transmitter."  Note in my application, the receiver also contains the current source for the circuit.
Any suggestions or ideas?
Tom
(459 Views)
Re: Dynamic PIL simulation of 4-20ma current loop sensor
Are you talking about HART communications? If so, there is the AM-9898 for CompactRIO with 4 mux'd channels.
Andrew T.
"His job is to shed light, and not to master" - Robert Hunter
(442 Views)
Thanks for the reply.
No, just talkin' plain old 4-20ma protocol without HART.  I will take a look at the product you mentioned; perhaps it would support the basic 4-20ma protocol as well as the HART.
Thanks again.
Tom
(434 Views)
Have a look at the NI-9265 module. You will also need a base unit.
Kees
(427 Views)
