Industrial Communications
Dynamic PIL simulation of 4-20ma current loop sensor
I am developing a Processor in the Loop (PIL) where I want to simulate sensors communicating via 4-20ma current loop protocol. I want to be able to dynamically (ie, under control of a computer) program the sensor value.  I see NI has a board the implements eight 4-20ma receivers.  I am looking for a device which can simulate a 4-20ma "transmitter."  Note in my application, the receiver also contains the current source for the circuit.
Any suggestions or ideas?
Tom
(2,868 Views)
Are you talking about HART communications? If so, there is the AM-9898 for CompactRIO with 4 mux'd channels.
Andrew T.
"His job is to shed light, and not to master" - Robert Hunter
(2,851 Views)
Thanks for the reply.
No, just talkin' plain old 4-20ma protocol without HART.  I will take a look at the product you mentioned; perhaps it would support the basic 4-20ma protocol as well as the HART.
Thanks again.
Tom
(2,843 Views)
Have a look at the NI-9265 module. You will also need a base unit.
Kees
(2,836 Views)
