Industrial Communications
Can you use the FPGA for Digital Inputs/Outputs if you are also using the CANOpen Module NI-9881 on the FPGA?
Hi All,
I'm looking to use a Digital Input and a Digital Output modules in the FPGA of a NI-9063 cRIO in addition to a CANOpen module (NI-9881) but from the following question/forum, it says that you need to run a blank VI on the FPGA. That will be difficult if I need to use it for the Digital Input/Output modules.
http://digital.ni.com/public.nsf/allkb/333860B4B66BA4BD86257E6100452593
I have succesfully communicated with the CANbus slave using a blank VI in the FPGA but has anybody run both a NI-9881 and Digital Inputs/Outputs from the same FPGA?
(3,765 Views)
According to that KB, cRIO-9063 already support NI-9881 by default. It means you don't need to compile a blank bitfile firstly from LabVIEW 2015 with CompactRIO 15.0.
Thanks!
(3,754 Views)
