Industrial Communications
Can I use EthernetIP on cRIO Realtime
I am getting this error message when I try to deploy to my cRIO  Deploying EthernetIP CIP Set Attribute Single.viEthernetIP CIP Set Attribute Single.vi loaded with errors on the target and was closed.
(5,761 Views)
Hi testtech,
Yes, Ethernet/IP is supported on real time. I would bet you haven't installed the library to the compact RIO. Try following this document and installing Industrial Communications for Ethernet/IP.
Jesse Dennis
Engineer
INTP
(5,754 Views)
