Hello All I have a new problem with cRio 9074 Max loses connection with cRio in work time. But network connection is ok. I can see it from cmd window. After restarting cRio, connection recovers. It becomes more and more frequently.
Hello Arham My cRio loses the connection in MAX and in Labview project randomly, but i can see connection in CMD with ping. I have 2 moduls NI 9423, NI 9501 in my project
Are you monitoring the memory and CPU usage from the distributed systems manager? And are you running the application in interactive mode? If the CPU is heavily loaded the code may still be running but the communication with the host PC is probably being interrupted.
I am interested to see what results you get from monitoring the memory and CPU usage in the distributed systems manager.
Regards
Arham H Applications Engineer National Instruments
