Hello Rashid,
IP on IPNet will be written using CLIP which is much better for implementing VHDL into your LabVIEW FPGA code. The following document discusses some of the differences between the two.
http://digital.ni.com/public.nsf/allkb/ce502221933fcceb8625750000011fb5?OpenDocument
Also, something to keep in mind, as of LabVIEW 2010 the HDL node will be deprecated so for future compatibility, you are better going the CLIP route.
