[IDLE] Israel LabVIEW User Group
Links for topics presented in the user group presentation on 22/9/2014
I'm putting a list of links here to provide a starting point for most of the points I discussed in the presentation. If any of the topics interest you more, you should search to find more material:
  1. Switcheroo
  2. Connector pane switcheroo -
  3. Quick reference card. The card can be found in <LabVIEW>\manuals\LV_Quick_Reference.pdf
    Examples of shortcuts from the card:
    1. Press space when wiring to change the wire route
    2. Display tools palette anywhere – shift + right click
    3. Ctrl+scroll in multi-frame structures to cycle through frames
  4. Error list – the VIs with actual errors are on top and have red Xs next to them.
  5. Place VI contents (Merge VIs)
    1. More.
  6. Snippets
    1. Code Capture Tool
    2. Note that the built-in snippets create problems if you use them on property nodes connected to controls or on controls with events. This problem doesn't happen with the CCT.
  7. Drag types into references to change the ref type. Right click on the reference to show the control -
  8. Drag VIs from explorer
  9. Context help for wire data type
  10. Ctrl+enter to set string constant size
    1. Related idea
  11. Quick Drop keyboard shortcuts
  12. LabVIEW speak
  13. Scripting springboard
  14. Project provider
    1. Example
  15. Custom and conditional probes
    1. History probes
  16. VI task manager from LAVA
  17. Numeric display format
  18. Jack Dunaway's events presentation -
    1. Video
    2. Code
  19. Call class property VIs from DVR
  20. Variant attributes
  21. Variant data type VIs
  22. Xcontrols –
    1. http://www.ni.com/webcast/2304/en/
    2. http://lavag.org/files/file/39-multi-column-listbox-xcontrol/
    3. http://lavag.org/files/category/16-x-controls/
  23. XNodes – WARNING – It's important to note that XNodes are not finished, they could cause problems, and they will probably be replaced by something else at some point in the future. You can use them, but be aware of these issues.
    1. Error ring constant – in the palettes.
    2. Math XNode
    3. Explanation and some links on how to start
  24. Shift+enter to add case to a structure, Ctrl+Shift+Enter to duplicate current case
  25. Different icons for different versions
You can find videos of many presentations from the last few years over here, with instructions on how to download them -
http://lavag.org/topic/16091-ni-week-2012-videos/
The videos from the CLA summit are generally at a high level, because the CLA summit is only for people who know LabVIEW and architecture well.
These are links to some ideas from the Idea Exchange. If there are other things you think of, you can search for them and add them if they're not there:
    1. http://forums.ni.com/t5/LabVIEW-Idea-Exchange/LabVIEW-for-Raspberry-Pi/idi-p/2082026
    2. http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Get-rid-of-the-quot-no-error-quot-part-of-the-error-cl...
    3. http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Flat-controls-indicators-and-containers/idi-p/919361
    4. http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Option-to-Show-Hide-the-Iteration-and-Count-Terminals-...
    5. http://forums.ni.com/t5/LabVIEW-Idea-Exchange/We-need-to-uncouple-the-quot-edit-mode-quot-FP-size-fr...
    6. http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Support-Unicode/idi-p/921449
    7. http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Use-a-terminal-block-to-access-the-for-loop-s-data/idi...
    8. http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Numeric-control-limits-should-default-to-quot-Coerce-q...
    9. http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Show-the-default-value-of-controls-in-subVIs-which-are...
    10. http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Supercharge-Quick-Drop-Turn-QD-keyboard-shortcuts-into...
    11. http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Add-an-easily-accessible-way-to-close-an-application/i...
    12. http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Add-Intellisense-support-to-the-property-node/idi-p/15...
    13. http://forums.ni.com/t5/LabVIEW-Idea-Exchange/Allow-clusters-to-have-quot-pages-quot/idi-p/1481862
I'm attaching a couple of controls. One is the multicolumn listbox shown in the presentation with an example of how to use it. The second is a listbox which is similar to the standard listbox, but has color for the symbols and some additional symbols.
___________________
Try to take over the world!
Message 1 of 1
(7,005 Views)
