Hyperception (RIDE, VAB)
Reply
How to authorize RIDE to other PC??
I have some edu. projects related with Hypersignal RIDE (Hyperception), DSK cards and SPEEDY33(NI product). So now we can't make unauthorization process in order to transfer our authorizing RIDE (and Block Diagram) to other PC. We know that at this time Hyperception RIDE belongs to NI and all problems related with RIDE shall take care by NI
Please let me know how to do authorization to my RIDE to other PC and some information about applications of NI-RIDE, NI-DSP module with SPEEDY33.
Thank you & Regards
Lee
Message 1 of 8
(15,875 Views)
Re: How to authorize RIDE to other PC??
The RIDE software required that the user authorize their installed software via the Hyperception website. NI has taken down this website and customers are no longer able to use this on-line authorization mechanism.
We have developed a simple patch program that will allow the user to bypass the authorization process. The attached compressed file can be used to resolve the reported authorization problem. If you un-zip & run the attached program then the RIDE software will register properly. Please let me know if you should have any questions or require any assistance.
Message 2 of 8
(15,854 Views)
Thanks man. I will try it out first.
Regards
Lee
Message 3 of 8
(15,847 Views)
I tried to authorize RIDE using the provided script on my primary workhorse Windows 10 computer.
The result is that I cannot remove RIDE and I cannot reinstall RIDE to correct the problem.
I am deadlocked due to changes that the installer script has made to the registry.
I have tried every combination of uninstalling, reinstalling, unauthorizing and authorizing  with both my 4.2 and 4.3 RIDE installation CD's.
Message 4 of 8
(7,236 Views)
Did the AuthUpdate program crash on Windows 10, or did it succeed and leave you in this deadlocked state?
I'm also assuming you can't uninstall because RIDE still views the software as authorized (at least at some level), and won't allow uninstallation.  Is that correct?
Message 5 of 8
(7,222 Views)
yes.
Message 6 of 8
(7,219 Views)
my RIDE uninstall is still deadlocked and I have tried everything. A full reinstall of the OS will cost me two days of repopulating my files and applications. Do I get a free copy of NI to replace the dead RIDE?
Message 7 of 8
(7,208 Views)
Highlighted
One additional question about the AuthUpdate.exe utility, since you mentioned that you are running on Windows 10.  Did you run the AuthUpdate.exe utility as an adminstrator on the computer ?  That utility was written long before Windows 10 came out and I seriously doubt it would run properly as anything other than administrator, so it begs the question.
Message 8 of 8
(7,187 Views)
