Huntsville Alabama LabVIEW User Group
HALUG November 2025: TestStand Sequential Process Model
The next HALUG meeting will be Wed, Nov 19, 2025, 12:00 PM - 1:00 PM at the GigaParts meeting room, 6123 University Dr NW, Huntsville, AL, US, 35806
Join us as we explore the Sequential Process Model of NI TestStand. TestStand is off-the-shelf test management software for validation and production test that eliminates the need for time-intensive in-house sequencer development and maintenance. The Sequential Process Model is a predefined framework used to execute test sequences one unit under test (UUT) at a time. It organizes the testing process by performing operations such as identifying the UUT, logging results, and notifying the operator of pass/fail status.
Hamilton Woods will discuss the TestStand process models, with emphasis on the Sequential Process Model. He will demonstrate how to perform flow control, logging and report generation, callbacks, LabVIEW calls, and how to share information between TestStand and LabVIEW.
(991 Views)
Links for this one:
In person event sign up - https://www.linkedin.com/events/halugnovember2025-teststandsequ7391232567745839104/
Live stream - https://www.youtube.com/live/4kn0rMr-UtE
Attendance check-in form - https://forms.gle/cdv31tghzFdYS5yd8
You will be emailed a certificate to the email given which you can use to submit attendance for recertification points
I saw my father do some work on a car once as a kid and I asked him "How did you know how to do that?" He responded "I didn't, I had to figure it out."
(961 Views)
Countdown to Huntsville Alabama LabVIEW User Group meeting ... 24 hours.
(943 Views)
