Hobbyist Toolkit
more Labview
Hi
Is it possible to install on the same computer two version of Labview?
For example Labview 2014 and Labview 2020 community Edition, without any conflict?
Can someone help me?
(1,186 Views)
Most any drivers you may be using will not be compatible with both versions as NI only supports back 3 versions (ex DAQmx 20 supports back to LabVIEW 2017).  And I don't think the community license will work with LabVIEW 2014.
GCentral
(1,183 Views)
i had previous issues with drivers, so installed the community edition on a virtual machine.
Jorge Augusto Pessatto Mondadori, PhD
Sistema Fiep
CLAD, CLD
(1,167 Views)
It is possible to install 2 versions of LabVIEW on the same computer but it is not possible to have 2 version of NI hardware drivers on the same system.  Personally due to this, I use virtual machines for each different version of LabVIEW.
David Wilt
The New Standard LLC
(1,154 Views)
