Most any drivers you may be using will not be compatible with both versions as NI only supports back 3 versions (ex DAQmx 20 supports back to LabVIEW 2017). And I don't think the community license will work with LabVIEW 2014.
There are only two ways to tell somebody thanks: Kudos and Marked Solutions Unofficial Forum Rules and Guidelines "Not that we are sufficient in ourselves to claim anything as coming from us, but our sufficiency is from God" - 2 Corinthians 3:5
It is possible to install 2 versions of LabVIEW on the same computer but it is not possible to have 2 version of NI hardware drivers on the same system. Personally due to this, I use virtual machines for each different version of LabVIEW.
