Hobbyist Toolkit
loss connection to target when deploy project to rpi 4
Every time i try to deploy a project to raspberry pi 4 i have got a message about losing connection to target. here's a screenshot
i have tried to many things. like
sudo schroot -c labview -d /usr/lib -- ln -s liblinxdevice_rpi2.so liblinxdevice.so
but none of theme works.
can any idea please?
thanks in advance.
Message 1 of 15
(4,216 Views)
What version of LabVIEW and LINX are you using?
What version of Raspberry Pi OS are you using?
Does this happen both when connecting over a wired Ethernet connection and WiFi?
David Wilt
The New Standard LLC
Message 2 of 15
(4,197 Views)
 version of LabVIEW 2020 community
version of Raspberry Pi OS : 10.7
this happen when connecting over wifi and Ethernet
Message 3 of 15
(4,194 Views)
Well it will be tricky to diagnose a WiFi issue as your setup could cause the issue.
Try a wired connection and does it work?
I post this before your update.  Well if the something happens over wired that is a different story.
David Wilt
Message 4 of 15
(4,180 Views)
the same thing does happens with wired connection!
i doubt about setting up Raspberry Pi with LabVIEW?
sudo sh -c 'echo "deb [trusted=yes] http://feeds.labviewmakerhub.com/debian/ binary/" >> /etc/apt/sources.list' sudo apt-get update
sudo apt-get install lvrt20-schroot -y
sudo mv /etc/systemd/system/multi-user.target.wants/nisysserver.service /lib/systemd/system
sudo mv /etc/systemd/system/multi-user.target.wants/labview.service /lib/systemd/system
# link liblinxdevice.so to the Raspberry PI device driver file liblinxdevice_rpi2.so
# Enable the nisysserver.service and labview.service to start on boot
sudo systemctl enable nisysserver.service
sudo systemctl enable labview.service
# Start the nisysserver.service and labview.service
sudo systemctl start nisysserver.service
sudo systemctl start labview.service
 did i forget anything?!
Message 5 of 15
(4,167 Views)
Why are you setting it up manually?  Why not use the tool built into LINX and LabVIEW 2020?
David Wilt
Message 6 of 15
(4,162 Views)
