Hobbyist Toolkit
Unable to reconnect to the target during LabView installation
Been trying to install the toolkit on a fresh compute module 4 (CM4) with a 64-bit Raspberry-Pi OS.
After getting to Labview -> Tools -> Hobbyist -> Target Configuration, I succeeded with connecting to target.
But when trying to install the kit, it cannot reconnect during the reboot (And cannot deploy the Blinky example).
Here is the Log:
Connecting to target...
Successfully connected to target.
Successfully connected to the target.
Target configuration updated.
OS Version: 11.5
CPU: BCM2835
Systemd Version:
Has Internet Access: True
Device Type: Raspberry Pi 2 B
blacklist spi-bcm2708is not present.dtparam=spi=on already exists.i2c-dev already exists.i2c-bcm2708 already exists.blacklist i2c-bcm2708is not present.dtparam=i2c1=on already exists.dtparam=i2c_arm=on already exists.
Adding MakerHub feed...
MakerHub Feed Already Exists
Updating package index. This may take over 30 seconds depending on your internet speed...
Installing LabVIEW...
Rebooting Target...
Unable to connect to the target. Please make sure the specified Hostname/IP, Username and Password are correct and try again. If this problem persists please search then create a thread on the Makerhub forums at labviewmakerhub.com/forums/linx.
Checking target status...
Installation completed successfully. Click Launch Example to get started.
OS Version: 11.5
CPU: BCM2835
Systemd Version:
Has Internet Access: False
I think it may be something with the:
1. Device Type (Raspberry Pi 2 B), as seen in the installation log above.
2. Wrong OS (64-bit) to use with the Hobbyist Toolkit. But I'm afraid of reinstalling the whole system again and get the same ending result.
Thank you,
Ran
(414 Views)
The device is likely fine (any RPi except for RPi 1 and RPi Zero should work).  But currently LabVIEW doesn't work on the 64-bit OS; I haven't had time to figure out why yet.
If you switch to a 32-bit OS, it should work.  You can also consider trying out an image with LabVIEW pre-installed.
(308 Views)
