09-04-2020 02:56 PM
I'm having trouble downloading the Diligent Linx and Makerhub Toolkit for LabView 2020 from VIPM. I am running macOS Catalina 10.15.5. Every time I try, I receive "Error Code: 1". Attached is a picture of the error code. I'm not sure what that means or I'm doing wrong so any help would be appreciated! 🙂
09-05-2020 10:21 AM
Does it claim to work with Mac Labview, or are you using Windows Labview on your MacOS? I was under the impression that LINX needs Windows to work... Please let me know where it says otherwise.
09-05-2020 10:35 AM
Does it claim to work with Mac Labview, or are you using Windows Labview on your MacOS? I was under the impression that LINX needs Windows to work... Please let me know where it says otherwise?
09-08-2020 11:35 AM
Honestly I'm not positive whether Linx requires windows to work but this is for a class and others with Macs in my class aren't having the same problem so I assume it works.
09-08-2020 12:19 PM - edited 09-08-2020 12:19 PM
I did a quick internet search and found this article. I am sure you can find more if you dig into it. If their mac system works and yours do not, I would question what is the difference between your hardware and theirs.... match it if you can... then match the software and settings if you can.... then see if that fixes it. Then go from there.
https://www.labviewmakerhub.com/forums/viewtopic.php?f=12&t=1626
