Hobbyist Toolkit
Target configuration loads with error
Hi, I've just run into an issue with target configuration. When selecting target configuration from the hobbyist menu, labview searches for some files, then opens the target configuration window with a broken arrow error. Clicking the broken arrow brings up the error window, which shows no error.
I tried performing a repair on the hobbyist toolkit and the recommended additional modules, rebooted, but got same behavior. Not sure what to troubleshoot next.
Any help is appreciated, thank you!
Message 1 of 8
(893 Views)
Apologies: Win11, LV2024 Q3 32-bit 24.3.4f4
Message 2 of 8
(860 Views)
Including an example of the files it searches for.
(I don't know how I managed to draw over the first screenshot, please ignore that 🙂 )
Message 3 of 8
(842 Views)
Hi FKhueson,
Are you using the community edition of LabVIEW or the professional version?
Which version of the Hobbyist toolkit did you install?
Do other LabVIEW example VI's run OK?
Message 4 of 8
(790 Views)
Hi Andy,
Using Professional, hobbyist version 2024 Q3. Just opened the B Spline Fitting Demo example and it runs fine. Also tried running a full repair on all LabVIEW products, no improvement.
Message 5 of 8
(780 Views)
I just uninstalled and reinstalled LabVIEW, and the problem persists. Are there files I need to delete in between uninstalling and reinstalling?
Message 6 of 8
(761 Views)
Accepted by topic author FKhueson
The Hobbyist toolkit installer creates files in the following folders in
C:\Program Files (x86)\National Instruments\LabVIEW 2024\
examples\MakerHub\LINX
help\Hobbyist
menus\Categories\Hobbyist
project\Hobbyist
vi.lib\MakerHub\LINX
The following NI page may be useful as it describes an error similar to your screen grab
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YQgfCAG&l=en-GB
Message 7 of 8
(734 Views)
Thanks for the link. I had found the directory the KB article mentions, and the files that are searched when opening the Target Configuration window are missing, though the directory was accessible. I switched the data directory path elsewhere, new files were generated, so I copied over the new files to the original data directory and switched the data directory path back to the original. Now the Target Configuration window loads properly.
Unsure why these didn't get included during installation or repair. Appreciate the help!
Message 8 of 8
(708 Views)
