03-16-2021 06:11 PM
I got a Raspberry Pi 4 today and I am very new. I have Buster version 10 installed (it came pre-loaded on the SD card from the kit). I have LabVIEW 2020 Community Edition (not SP1). I was able to connect to my raspberry pi in the LINX target config and I updated the software via the target config. After that I added my raspberry pi to my project and connected to it successfully. When I try to run the blink VI, it doesn't work. I have the LED setup correctly with a 220 ohm resistor, wiring is correct on pin 7 (4th pin down on the left if looking with usb ports on top). Any ideas on what could be wrong?
03-16-2021 06:51 PM
There is information about the Raspberry PI GPIO pinout here:
https://www.raspberrypi.org/documentation/usage/gpio/
You could test the LED with series resistor by connecting it to pin 1 (3.3V) instead of pin 7.
03-16-2021 07:14 PM
So, the I tested the 3.3V and 5V pins and got no response from the LED. I tested the LED on my Arduino 5V pin and it worked fine. Is there something you need to do to activate the GPIO pins?
03-19-2021 08:26 AM
Are you setting the Digital Output Channel to 7 on the LabVIEW UI ?
03-19-2021 09:14 PM
Hello, could you tell me how you managed to configure the Raspberry Pi 4 to LINX, I'm having difficulties
03-19-2021 09:19 PM
I had the Pi backwards. Everything is working now.
03-19-2021 09:21 PM
Mine was easy because I bought a kit with an OS pre-loaded onto an SD card. So I just installed that and then updated the firmware via the target configuration.
