09-18-2020 11:24 AM
Odd right?
I just noticed it. I am using the Labview community 2020 32 bit LINX that I opened up to find this. Can anyone else with my version or other confirm this same code layout?
09-19-2020 01:31 PM
Check the actual VI name. In my Linx 2014 version the VI also has the open icon, but it really is the "Local IO\LinxI2cClose.vi"
09-22-2020 04:37 PM
Thanks for the tip, but I opened up the VI and it went to
LMH-LINX.lvlib:Local IO.lvlib:LinxI2cOpen.vi
09-22-2020 08:38 PM - edited 09-22-2020 08:38 PM
09-24-2020 02:52 PM
No, this is a valid call to the LinxI2cClose function from the shared library. Only the wrong icon on Close Vi.
09-24-2020 06:40 PM
Is this Linx/LabVIEW 2020? Because I see the same as you with Linx for LabVIEW 2014 but the OP claims that it opens the LinxI2COpen VI for him when opening that icon.
09-24-2020 06:56 PM
Yes, Its LINX/LabView2020. And I just noticed that the i2c bus channel selection wire (marked in red) is not connected in I2C Close.vi (Local IO frame).
