04-30-2022 09:56 AM
Face the connection issue:
Connection is fine for the first time.
And then run the example, first time it is working fine, but remind the connection is lost as the below figure. Even I have already disable the "close.vi" on the block diagram, but still show a warning which the connection is lost.
And actually the target is really lost, because when I run this VI again, show it was failed to connect to the target.
If this case was happened, I can't resume this connection by just configure the LINX Target Configuration, the only way is to reboot the raspberry pi board.
So my question:
Is there any way to re-open the connection correctly? or I make some other mistake? Any suggestion will be helpful, thanks a lot.
Home--colinzhang.net: My Blog
Solved! Go to Solution.
04-30-2022 10:48 AM
I resolved this issue after disable the 1-wire interface. The detail is as this discussion,
