Hobbyist Toolkit
Linx for Labview 2020 Error 5003
There is a bug in the Hobbyist Toolkit. Replace C:\Program Files (x86)\National Instruments\LabVIEW 2021\vi.lib\MakerHub\LINX\Private\Device\Utilities\Packet Number.vi with the version attached.
Message 21 of 27
(4,527 Views)
Hi, Comporder 1. I would be interested on understanding a bit more about such bug solution. Unfortunately my version is 2020 and I cannot open your file to check it.
Could you please, save it for a previous version?
Message 22 of 27
(4,478 Views)
DDuff discovered the fix/workaround and does a very good job of explaining and giving pictures in message 7 of this thread.
Message 23 of 27
(4,465 Views)
Oh. It is true. It is a summary. I understood a new possible solution was proposed.
Thank you all.
Message 24 of 27
(4,450 Views)
I spent hours trying to get my Mega to work! Thank you! I hope they fix that delay in their VI's permanently. Its sad on the "easy" example I could not get it to RUN! I was this close of giving up and not using LabVIEW
Message 25 of 27
(3,871 Views)
Yes Comporder 1 provided the solution, it is a bug og LINX
Message 26 of 27
(3,824 Views)
OMG, thank u so much for this! Im here, in 2025, to say u are a genius, Comporder1. You saved my life. My labview 2025 had the same bug. Thx for the help.
Message 27 of 27
(700 Views)
