Hobbyist Toolkit
LINX and Raspberry Pi4 Mis-identification Issues
ROlf,
I am looking forward to what you are developing. after reading through the thread I am sort fo glad Iam not alone with the issues with the RPi3 and RPi4 ( in my case serial use).
Sounds like you might have some of that resolved in what you are creating..
Jeff D.
Certified Architect LabVIEW Champion DQMH Framework
Message 21 of 29
(3,619 Views)
I was trying to get back with this for LabVIEW 2020. HAd a nice VMWare image with LabVIEW 2020 and thought it would be cool to upgrade that to LabVIEW 2020 SP1. NOT!
Now LabVIEW crashes silently about 2 seconds after starting up and showing the splash screen. No crash dialog, nothing! It just shows the splash screen and poof, it's gone.
Going to deinstall all NI related stuff and reinstalling SP1 from scratch. Keep fingers crossed.
Rolf Kalbermatter  My Blog
Message 22 of 29
(3,610 Views)
in labview use linx , all the labview vis ,only digital write and read functions can run successfully,.
other vis report error , such as pwm. spi . iic.
Message 23 of 29
(3,580 Views)
Hey Rolf, Ever get any further? It is kind of unfortunate that NI was talking about LabVIEW and RPi yet several things don't work ON THE RPi 3 and 4
Jeff D.
Message 24 of 29
(3,496 Views)
Hello. Anyone was able to make the Pi 4 work properly? I'm in this issue about 2 weeks, and always end with nothing. Thanks
Message 25 of 29
(3,266 Views)
Yes, I am working with both a RPi3 and RPi4.  I can swap the SD cards between the 2 and it works on both.  The only issue I have seen is it appears the program may stop running on the RPi4 after a period of time, days of continuous execution, but I have not looked into this to determine what is going on.  I power cycler always starts the program again.  I do not see this on the RPi3 I have.
David Wilt
The New Standard LLC
Message 26 of 29
(3,262 Views)
Very nice. I was able to make the serial work fine in PI 4?
Message 27 of 29
(3,253 Views)
I am not using serial at this time so I can't provide any input on that.  I would suggest making a new post with your exact issue to try and get some help.
David Wilt
Message 28 of 29
(3,249 Views)
Is this the functioning workaround for getting LV to recognize my pi4 as a pi4 and not a pi2?
Message 29 of 29
(2,123 Views)
