01-22-2021 11:27 AM
01-22-2021 12:50 PM
I was trying to get back with this for LabVIEW 2020. HAd a nice VMWare image with LabVIEW 2020 and thought it would be cool to upgrade that to LabVIEW 2020 SP1. NOT!
Now LabVIEW crashes silently about 2 seconds after starting up and showing the splash screen. No crash dialog, nothing! It just shows the splash screen and poof, it's gone.
Going to deinstall all NI related stuff and reinstalling SP1 from scratch. Keep fingers crossed.
01-25-2021 06:29 PM
in labview use linx , all the labview vis ,only digital write and read functions can run successfully,.
other vis report error , such as pwm. spi . iic.
03-19-2021 08:22 AM
06-25-2021 01:58 PM
Hello. Anyone was able to make the Pi 4 work properly? I'm in this issue about 2 weeks, and always end with nothing. Thanks
06-25-2021 02:33 PM
Yes, I am working with both a RPi3 and RPi4. I can swap the SD cards between the 2 and it works on both. The only issue I have seen is it appears the program may stop running on the RPi4 after a period of time, days of continuous execution, but I have not looked into this to determine what is going on. I power cycler always starts the program again. I do not see this on the RPi3 I have.
06-25-2021 05:27 PM
Very nice. I was able to make the serial work fine in PI 4?
06-25-2021 05:45 PM
I am not using serial at this time so I can't provide any input on that. I would suggest making a new post with your exact issue to try and get some help.
