Hobbyist Toolkit
I am trying to simulate LabVIEW 20202 and makerHub LINX using proteus program.
I am trying to simulate LabVIEW 20202 and makerHub LINX using proteus Version 8.11 program. Because of Corona, it is because of the online LabVIEW lecture. Of course, most of the LINX functions work well with the Arduino Board, but if you use the proteus, it will not run. After loading the Arduino Hex file to the Proteus, I am connecting to the proteus using a virtual serial port, but no matter how much I do, it does not work.
(1,323 Views)
I have exactly the same problem, and still could not find the solution, there is a tutorial on youtube showing how to do so, but even trying that won't work.
(1,128 Views)
