Hobbyist Toolkit
Digital IO on RPi5 fixed!
Due to hardware changes with the RPi5 model, LINX Digital IO never really worked correctly on this board.  Thanks to the outstanding contributions of @AndyLB, that issue has been fixed in the current version of LabVIEW Community Edition (24Q1).
You can get this update using the configuration utility or, if you're doing a fresh install, you can use the pre-built images available here.
Message 1 of 1
(937 Views)
