Hobbyist Toolkit
Chipkit wi-fire cannot generate PWM
Hi all,
Background:
I am working on a project which uses chipkit wi-fire to generate the PWM to control the lighting unit. the software configuration is LabVIEW 2019 (Linx)
Problem:
I can flash the firmware to chipkit board successfully. When i try to use pin 3 to output PWM but fail, the board output 0 or 3.3V.
Is there any way to set the pin action?
thanks
Andy
(240 Views)
hi all,
May i have some tips for debug?
thanks
Andy
(184 Views)
