Hobbyist Toolkit
Buenas a todos! Tengo dudas de como utilizar labview con una raspberry, la idea es hacer una secuencia con leds usando la I/O de la raspberry
La idea final es utilizar relay de 5vdc y encendee electrovalvulas y remplazae un pequeño PLC de 5 sensores y 5 salidas.
Gracias!
(2,045 Views)
It's all very doable! Do you have any experience in electrotechnics? How to wire up a LED so it can work and doesn't burn right away? Calculating resistors from the voltage and current?
And done any program before?
Rolf Kalbermatter
Averna BV
(2,016 Views)
