Hobbyist Toolkit
AHT10 I2C reading error
I am trying to read AHT10 from LINX. I don't know how to read the code. Please tell us.
 THNK YOU..
(286 Views)
hello mep2019. you need a documentation of this code, or you created this code and the values read are wrong? what is happening?
i downloaded your code, but i don't have this sensor here, please describe your issues with more details.
Jorge Augusto Pessatto Mondadori, PhD
Sistema Fiep
CLAD, CLD
(267 Views)
Thank you
I am trying to read the temperature value
Can you check if my code is wrong?
(234 Views)
somethings are a bit odd.
i'd recommend initializing communication and sensor outside the while loop.
also, i recomend using loop acquisition bigger than 2 seconds, in conformity with sensor datasheet to avoid overheating.
i can not develop this code, don't have this sensor here to test. but recently i gave some instructions that worked out for some colleagues.
first, get used to how the sensor works, reading its datasheet and using arduino libraries (they are good sources of information) as a guide:
https://server4.eca.ir/eshop/AHT10/Aosong_AHT10_en_draft_0c.pdf
https://github.com/enjoyneering/AHT10
here are the links for the answers i gave. check out if those can help you:
https://forums.ni.com/t5/Hobbyist-Toolkit/Using-multiple-sensors-together-with-linx/m-p/4150738#M745
https://forums.ni.com/t5/Hobbyist-Toolkit/Vi-for-VELM6075/m-p/4151957#M749
also, another possibility is to implement the library in your microcontroller main loop and use custom command to request information from the sensor.:
https://web.archive.org/web/20200806103634/https://www.labviewmakerhub.com/doku.php?id=learn:tutoria...
hope it helps
Sistema Fiep
CLAD, CLD
(225 Views)
