High-Speed Digitizers
synchronizing 2 CPCI 5122 Boards using External Sampling Clock or External Reference Clock
I need to synchronize 2 CPCI 5122 Boards with an external signal, and to trigger acquisitions with 2 different external digital triggers. I have 2 ways to do it:
1/ Using the same external sampling clock distributed 2 times on "CLOCK IN" Board1 and "CLOCK IN" Board2 but in this can I use at the same time 2 different external digital triggers?
2/ Using the same external reference clock signal:
2.1/ It is possible to input only one ext ref clk signal in the "CLOCK IN" Board1 and distribute it from "CLOCK OUT" Board1 to "CLOCK IN" Board2?
2.2/ If 2.1 possible can I use at the same time 2 different external digital triggers?
2.3/ If 2.1 not possible (so in this case I use 2 ext ref clock) can I use at the same time 2 different external digital triggers?
Guillaume R
Engineer in Electronics
(6,379 Views)
To share signals between 2 PCI devices, you can use RTSI lines. But you need a RTSI cable.
NI-Scope 2.0 includes synchronization examples to get you started.
http://www.ni.com/support/digitizers/faq.htm#preparetest
Isabelle
Ingénieur d'applications
National Instruments France
(6,365 Views)
Guillaume,
You mentioned that you are using 2 CPCI (PXI) 5122 boards. Are you using them in a PXI chassis? If you are, then the best way to synchronize these modules is using the TClk technology designed for these devices. Please start with the help file installed on your machine with NI-SCOPE 2.7 at the following default location:
C:\Program Files\IVI\Drivers\niTClk\Documentation\nitclk.chm
For more information on TClk, please see our white paper:
http://zone.ni.com/devzone/conceptd.nsf/webmain/3F345C6E4BC82F3886256EE100572B16
If you still need assistance after referring to the above documentation, please feel free to contact us.
Thank you,
Josh
(6,359 Views)
