I'm using a PXIe-5105 high speed digitizer to acquire X, Y, and Z (intensity) signals and display them in an intensity graph. This simulates the old analog oscilloscope xyz mode that acts like a vector display. In short, I need a transparent color for the smallest Z value, but this doesn't seem possible.
The other graphs and charts allow the background to be set to transparent. It appears I can set the background of the intensity graph to transparent, but the problem comes in when plotting the Z values. Right now the Z values ranges from 0 (black) to 255 (white). If I try to force the Z marker value for zero to a transparent color constant, the program errors out saying that's an invalid value, whereas other colors work.
I pre-initialize my 1024x1024 drawing array to 0, then "draw" into the array at the corresponding X and Y coordinates with the Z value. This results in a white graph on black background in an intensity chart. I need a transparent background because the graph is going to be overlaid onto a video.
Should I be looking at some sort of picture control instead?
