High-Speed Digitizers
Problem of using niScope.lib in VS2015
Accepted by wsxxdzlj
Hi Ancher,
I can give you my solution here:
  I add the file "legacy_stdio_definitions.lib" to "Linker -> Input -> Additional Dependencies". Then, the problem is solved. I use Win10, VS2015 and my software is released in 64-bit.
It works on my software. I am not sure whether it is still work for you. If you try my method, please give me your feedback. Thanks.
Message 11 of 15
(2,867 Views)
Hello Balexand,
My version of niScope_32.dll is 4.3.0.49152  / 4.3.0f0, it's OK.
With your library, it compile fine, thanks a lot for this.
I don't use LabWindows/CVI, so I yhink thaht the kind of trouble you feel doesn't append to me.
Thanks again, this "special" release allows me to work until the next release.
Regards.
Message 12 of 15
(2,854 Views)
Hello wsxxdzlj,
I don't tried your solution, with the library delivered by Balexand I have linked without any error.
Anyway, thanks for your solution, it can be very useful for some other people.
Regards.
Message 13 of 15
(2,851 Views)
Hi Nathan,
Now NI-SCOPE version is 16.0. However, this issue is still not solved. Is there any news about solving this issue?
Message 14 of 15
(2,189 Views)
Changes that went into NI-SCOPE 16.0 were mostly just for LabVIEW 2016 support.  You may notice that niScope_32.dll is still the same version (4.3.0f0).
We are aware that this issue is still open.  It is being tracked as Bug ID 546023.
Message 15 of 15
(2,171 Views)
