08-20-2012 03:05 AM
Dear Tunde,
The issue has been resolved. Thank you for your help.
07-01-2016 05:24 AM - edited 07-01-2016 05:25 AM
Dear Tunde,
I am using NI PXI-5152 digitizer and I am trying to acquire a analog signal in LabVIEW using NI-Scope express through channel 0. Am also getting the same error
Error - 1074118540 occurred at Error occurred at : niScope Initiate Acquisition.vi:1
Possible reason(s):
Driver Status : (Hex 0xBFFA4074)
Requested vertical range is invalid.
Device: PXI1Slot3
Channel Name : 0
Status Code: -200579
Please find attached code where I use Ni-Scope express !
Please clarify the same !
V P Karthik
Research Scholar
IIT Madras
07-06-2016 10:12 AM
Hi vpkboss,
This thread is really old (the last post was in 2012). You're going to be much more likely to get some help with your issue if you make a new thread, for visibility. Include the information you put in your post here, as well as a little background on your setup: are you using an embedded controller or MXI connection? What OS and software versions are you using? That kind of thing. That will increase the likelihood of other people seeing your post and being able to help.
Cason
Applications Engr., NI
07-06-2016 11:40 AM
Dear Cason,
Thanks for the reply. I have made a new post with suggested information ! Please review the same !
Thanks.
V P Karthik
