From 11:00 PM CST Friday, Feb 14th - 6:30 PM CST Saturday, Feb 15th, ni.com will undergo system upgrades that may result in temporary service interruption.
03-05-2008 12:57 PM
One more thing..The newer versions of NI SCOPE that support PXI 5152 also need newer versions of DAQMx that does not support LV7.0.
It would be helpful is some one can some one point me to the latest version of DAQMx that supports LV7.0 and a corresponding NI SCOPE version that supports 5152
I was unable to identify a correct combination that worked for me!..
03-06-2008 09:55 PM
The latest version of DAQmx compatible with Labview 7.0 is DAQmx 8.1. The latest version of NI-Scope compatible with Labview 7.0 is NI-Scope 3.0. However, there is a bigger issue here related to the 5152 device.
The NI 5152 (PXI version) is supported on NI-Scope 3.2 or later. The NI-Scope 3.2 requires Labview 7.1 or later. Thus the current setup of Labview 7.0 paired with the 5152 is not supported. I am sorry for the inconvenience. You are basically looking at upgrading to newer version of Labview or selecting another digitizer device supported by the NI-Scope 3.0 driver. Please give me some feedback so I can help further guide you to a solution. If you are interested in reviewing the information I have posted, please view the attached links.
NI-DAQ & LabVIEW Version Compatibility (for Windows)
03-06-2008 11:29 PM - edited 03-06-2008 11:37 PM
03-10-2008 10:51 AM
03-10-2008 10:34 PM
03-12-2008 11:39 AM - edited 03-12-2008 11:42 AM
I just saw that you have a duplicate post.
Forum Post: How to get PXI 5152 working in LabVIEW 7.0
03-12-2008 10:05 PM - edited 03-12-2008 10:06 PM
03-13-2008 11:36 AM
