High-Speed Digitizers
PXI-5152 MIG hardware error
Scope card PXI-5152 Serial Number: 0xE95906
Chassis: PXI-1045
Software: NI-SCOPE 3.7, LabVIEW 8.5, TestStand 4.0.1
Scope measurements return sometimes this error:
Error Message: niScope Multi Read WDT.vi:1Internal Hardware Error occurred in MIG hardware. Please contact National Instruments Support.
Component Name: nihsdrk
File Name: p:\Measurements\DHV\DIDE\export\2.5\2.5.0f2\includes\nidide\timing\tSharedTimingChip.cpp
Line Number: 1491
Status Code: -238801
Internal Hardware Error occurred in MIG hardware. Please contact National Instruments Support. [Error Code: -238801]
Message 1 of 8
(7,370 Views)
Do you know what wrong is with this Scope card?
What we should do?
Message 2 of 8
(7,353 Views)
Hi JCC (SK),
Has the hardware ever ran successfully?
Can you confirm if you are using LabVIEW 8.5 or 8.5.1 as the scope 3.6 driver doesn't explicitly mention supporting 8.5 in the readme file. It may be worth trying to use the scope 3.4 driver to see if it resolves the problem.
If this doesn't help, the problem will most probably lie in the hardware, you should contact your local National Instruments branch to find some further troubleshooting steps and information about repair or replacement options. In the UK the contact number is 01635-523-545.
Stephen C
Applications Engineer
Message 3 of 8
(7,347 Views)
Hi Stephen
You are right NI-Scope version is not correct.
There is LabVIEW 8.5 installed in the system and originally NI-Scope version 3.4.1f6 was installed.
Customer installed NI-Scope 3.7 to the system. I don't know why.
Could be this higher version of NI-Scope source of my problem?
Looking forward to your answer
 Peter
Message 4 of 8
(7,335 Views)
Hi Peter,
I had a look through our internal resources and the error code does not appear often enough for me to be able to single out the cause of the problem.
I suspect that it may be a hardware fault but I would certainly check the driver as a first troubleshooting stage.
Stephen C
Message 5 of 8
(7,332 Views)
Hi Stephen
Dose it mean that I should downgrade to NI-Scope drivers which support LabVIEW 8.5?
Message 6 of 8
(7,327 Views)
Hi Peter,
Yes, I would try to downgrade to NI Scope 3.4. This one is definitely supported by LabVIEW 8.5.
Stephen C
Message 7 of 8
(7,322 Views)
Hi Peter,
Could you try to run the following three from MAX (Measurement & Automation Explorer)?
1. Device Reset
2. Self-Test
3. Self-Calibration
If you see any errors on this, please let us know what those are.
If all of these seem to work correctly (without errors) could you please describe what your code is doing?  Are you able to reduce the code down into something very simple, which reproduces the issue, in LabVIEW?  It would be ideal if we could see a shipping example for NI-SCOPE with a particular configuration which reproduces the issue.
Could you also describe your system setup?  Are you using a PXI or PXIe controller with the PXI-5152?  Or are you using a MXI controller to a desktop computer?
Which chassis are you using it in? (1075, 1065, 1045, etc.)  Which slot?
-Andrew
Message 8 of 8
(7,305 Views)
