I am using a PXI 5124 (internal PXI Clock) triggert by a PXI 6602. Today I got this error report:
Error -1074116135 occurred at niScope Initialize.vi
Possible reason(s):
Error: (Hex 0xBFFA49D9) DAQmx Error -200550 occurred:
Hardware clocking error occurred.
If you are using an external reference or sample clock, make sure it is
connected and within the jitter and voltage level specifications. Also,
verify that its rate matches the specified clo
Elaboration: Status Code: -200550
The vi (LabView 7.1) was running well over 2 years. Of course I
constantly did some modifications on the program but without touching
the scope- or timing-session. The 10MHz Ref-Clock on the rear panel
looks fine. Restarting PXI and Computer dosn't help, the "ACTIVE"-LED
lights even before running the vi.
Thanks for your help.
Christian
