10-28-2010 05:18 AM
i'm using a PXI 5105 with LV SignalExpress.
I want to measure the voltage of embedded system card with power supply of 5 V.
I want to tune the offset but when i set a value, i have the error:
"Requested vertical offset invalid."
Voltage Range is : 5V
Offset is : 4V
Impedance is : 1Mohms
What's wrong ?
Best regards
Nicolas
Solved! Go to Solution.
10-28-2010 10:40 AM
Hi Nicolas,
Unfortunately, the NI 5105 does not support voltage offsets. For a quick rundown of supported features, please refer to the Features Supported by Device section of the High-Speed Digitizers Help. Best regards,
11-02-2010 03:48 AM
Hi Daniel,
Thank you, i miss this one.
Best regards
Nicolas
