Jerome,
You are exactly correct, it is in fact a running average which calculates a new result each time that it is called. This means that the "number of averages" will correspond exactly to the number of times you call it (minus one since the first time it will just return exactly the data that was acquired). The average array is cleared by calling
niScope Clear Waveform Measurement Stats with the
measurement function parameter set to Multi Acq Average.
This information is located in the NI High-Speed Digitizers Help, which is in your Windows Start menu and also downloadable
here.
Alan L
Message Edited by Alan L on 07-18-2005 12:18 PM
