High-Speed Digitizers
How to get the triger time with NI5102?
Now I am using digitizer NI5102 and get the sample points with the function niScope_Fetch.
However,I can't get(calculate) the triger time because the value of absoluteInitialX ,which is
one of the elements of niScope_Fetch's last parameter,is always 0.When it comes to NI5112,
all work well.NI5102 doesn't support this function,does it?Thank you!"
(5,252 Views)
absoluteInitialX is not supported on the NI 5102 (it is not capable of this). relativeInitialX is supported though.
Hope this helps!
(5,252 Views)
