Here is the clocking scheme, reading the text, it seems that it is only be possible to route the sample-clock /N to CLK-OUT if you also sample with decimation. But worth a try.. have a look at the Digitizer HELP (clocking/ horizontal/routing properties) and try-out.
Don't know, if it's possible to set the divisor N and use the routing while telling the ADC and memory manager to use sample-clock instead of sample-clock/N ...
Since you run a PXI system, what other cards do you have , what tasks do they run?
Greetings from Germany
Henrik
LV since v3.1
