01-15-2018 10:50 AM
This is my first time with National Instruments products, I really find the website difficult to browse through. Google search seems more straight forward to browse NI products.
Any advise is much appreciated.
01-16-2018 04:28 PM
Hi mariasuku,
I hope this helps answer some of your questions:
Top 10 Things to Consider When Selecting a Digitizer/Oscilloscope
http://www.ni.com/white-paper/4333/en/
I hope this helps!
01-17-2018 09:58 AM
Thank you for the white paper, I prefer to stick with NI products for now for it seamlessly connects via LabVIEW.
If I want to generate pulse wave with programmable duty cycle, width, amplitude, rate, etc. what should I lookout for ? Timers/Counters modules or something else ?
01-17-2018 10:56 AM
Start here:
http://ni.com/signalgenerators
If you get a PXI waveform generator, like the PXIe-5413, PXIe-5423, or PXIe-5433, you can control amplitude, frequency, and duty cycle of a square wave using Standard Function mode of the NI-FGEN API:
http://zone.ni.com/reference/en-XX/help/370524T-01/TOC341.htm
01-17-2018 07:34 PM
Thank you, starting from your suggested modules, I also had a look at the Model: Astronics PXIe-1209 [Part Number: 785033-01].
