07-21-2005 03:10 PM
07-21-2005 03:16 PM
Hello:
I have a NI-5112 and using External Channel to trigger the waveforms acquisitions of other channels CH0 and CH1.
I want to measure the frequency of this external trigger. Is it possible ?
Thanks.
07-22-2005 01:22 PM
07-23-2005 08:58 AM
Hello Brooks:
Thank you for attention !
I will try to explain my application:
I need to measure a signal of a speed/position sensor. This sensor works with hall effect principle and is placed in front of a wheel with some teethes. Is used for automotive purpose in CAM and CRANKSHAFT applications. So, I need to measure period, duty cycle, rise time, fall time, Vpp, Angles for each teeth x encoder, everything from 40 to 7500 rpm.
I'm using CH0 to measure a signal of this speed/position sensor.
I'm using CH1 to measure a signal of an encoder connected to wheel.
I'm using EXT Trigger to sync acquisition with encoder's INDEX signal.
I need to measure the frequency of EXT trigger to know the instantly speed of the wheel.
So, If I know that my encoder has 2048 pulse/rev, I can measure FFT_FREQUENCY of CH1 with scalar measurement functions and calculate the speed !
The NI-Scope is wonderful because it can measure a lot of things automatic and fast, like period, frequency, duty cycle, rise/fall times ...
Now I have one more question:
I want to use 10:1 attenuation but I can't use a common probe. I want to connect the CH0 to sensor with a special connector.
I've tried to make the same circuit with 9MOhms and capacitor like explained on site, but I reached bad results. The industrial probes has special characteristics for capacitance and noise rejection.
Do you know how can I solve it ?
Thank you.
07-25-2005 03:39 PM
Hi Marcelo,
I would really like
to help you with this issue but I have no training in probe
design. I am trained in NI hardware and software and I will be
happy to help you with this.
Best Regards,
Brooks W.
