05-18-2018 02:44 PM
The following hidden gems are new to LabVIEW 2018:
Note that for LabVIEW 2018, there is not a new Hidden Gems package on the Tools Network. Version 1.0.0.10 continues to be the latest version.
05-24-2018 05:04 PM
So many great examples of defining an interface for extending the inbuilt LV functionalities with your own algorithm details (lambda functions), defining object oriented types etc. yet nothing provided as a real interface, making it impossible to actually extend this and provide your own types. Why is it that smart steps in the right direction get hidden and buried? Why not just do it right once, and not these timid steps behind the scenes? These kind of features should have been in LV 10 years ago.
03-27-2019 02:55 PM
Will these show up in Quick Drop in another release?
03-27-2019 03:04 PM
I have not yet assessed whether there will be a new Hidden Gems package for the NIWeek 2019 release. I can say that LabVIEW 2019 includes a 'Synchronize Data Flow.vim' in the Synchronization palette that is an updated version of the Sync.vim hidden gem I mentioned above.
Also note that even if we do update the Hidden Gems package, we probably won't include palette entries for files in the examples folder.
02-03-2020 03:38 PM
I know this is an old thread but I just stumbled across Sync.vim (after making one of my own). Apologies if this is fixed in LV2019+; I'm still on 2018.
What's the purpose of the sequence structure frame here? Shouldn't the subVI boundary accomplish the same thing? Just wondering if there is a compiler optimization thing going on that I'm not seeing. My version just had a/a' and b/b' connected without anything else, and it behaves exactly the same.
02-03-2020 03:40 PM
As far as I know, the sequence structure is not necessary to accomplish the same task.
02-03-2020 11:51 PM
Hey Bert,
I think it is because it is a malleable VI. These have to run inline which essentially removes the subVI boundary hence the sequence structure.
I've hit similar issues in the past where I inlined a VI but then the error line doesn't wait for the rest of the code to execute!
Cheers,
James
02-04-2020 10:25 AM
The flat sequence isn't necessary. The subVI boundary provides the synchronization, even with inline VIs. There should never have been a time where inlined VIs did not synchronize on the subVI boundary. James, if you can reproduce the issue, it should be filed as a bug report.
