08-24-2015 01:54 PM
The new version of the Hidden Gems in vi.lib package is available for download on the LabVIEW Tools Network. It is version 1.0.0.8. It exposes the following new VIs in LabVIEW 2015:
The new hidden gems package will also remove the deprecated VariantDataType VIs from the hidden gems "Variant" palette, since these VIs were promoted to an official API in LabVIEW 2015, as discussed here. Note that this VI removal only affects LabVIEW 2015 and later. The VIs are still available in the hidden gems Variant palette in LabVIEW 2014 and previous.
Note that if you install hidden gems 1.0.0.8 to LabVIEW 2014 or previous, two empty palettes will appear (for the progress bar VIs and the shortcut menu plug-in helper VIs), since those VIs are only available in LabVIEW 2015 and later.
