Hardware Developers Community - NI sbRIO & SOM
sbRIO-9651 SD Card Dispaly
Dear Community,
I'm trying to read a SDHC 32GB Card FAT fomatted from the NI 9651 carrier board.
I insert the SD card and the DS5 Led power up but I'm unable to see it from the device&interface in NI MAX nor in the system webpage.
Can you help?
BR
M
(5,068 Views)
Hi cortexM,
You will not be able to see the SD card from MAX nor the system webpage. It will present itself in the same way as a USB flash drive if you have used those in the past on the RIO platform. It mounts as a U: drive. If there is already removable media installed, it will show up as V:, W:, etc.
If you have FTP enabled, you should be able to navigate to that drive; otherwise, you use the appropriate filepath in LabVIEW to target the SD card.
I have found that the Get Volume Info VI works well to identify if you have an SD card inserted or not. I actually responded to a similar question a while back on the forums.
http://forums.ni.com/t5/Real-Time-Measurement-and/How-to-write-data-to-SDHC-card-on-9636-board/td-p/...
Let me know if I am not fully understanding your question.
- Tanner
Tannerite
(3,820 Views)
Perfect!
That's the info I needed!
Thank you,
M
(3,820 Views)
