Hardware Developers Community - NI sbRIO & SOM
Why my USB Web cam is not recognized by sbRIO-9607?
Hi Richie,
I tried it with the same software components listed in your report and still no luck. Moving forward I think the best option is for you to open a Service Request with NI China. That will give us a local contact and mechanism to exchange hardware to do some more in-depth troubleshooting. I'll send you an email with more details.
-Will
Message 11 of 15
(1,559 Views)
Reference#7755445
Message 12 of 15
(1,548 Views)
I have tried to connect my webcam to sb-RIO 9637, I have tried to connect them through USB 3.0 hub, still cannot see it in MAX.
How did you make them work?
Message 13 of 15
(1,167 Views)
What model? You probably want to make sure you webcam supports genicam. Also, you should probably make your own thread. Ideally in the sbrio software form as this is likely a software issue.
Message 14 of 15
(1,163 Views)
Most of the cameras are working after installation of LabVIEW 2023 Q1 and NI Linux Real-Time ARMv7-A 4.14.146-rt67 on target with Vision Development and IMAQdx  support.
Message 15 of 15
(470 Views)
