Hardware Developers Community - NI sbRIO & SOM
Reply
Highlighted
Solved! Go to solution
Who is claiming my Block RAM!?
Dear colleagues,
I am programming a sbrio-9606, whose LX45 FPGA has, as you surely know, 116 BRAMs (short for Block RAM), sizeable as Length*Width = 16k*1b = 8k*2b = ... = 1k*16b = 1/2k*32b.
As a result, because I need to implement 10 tables of 10,000 16-bit words each, my design consumes 100 BRAMs. This would leave 16 BRAMs available, right? ... wrong!: only 13 are shown as available!
I wonder who is eating the remaining 3 BRAMs!
And, generally speaking, is there any way to know who in your design is claiming the FPGA's BRAMs?
Biscay.
(676 Views)
Re: Who is claiming my Block RAM!?
Try to compile an empty VI and see how much BRAM it consumes. I think there are some logic underneath used for LabVIEW to communicate with the FPGA.
(657 Views)
Hi Biscay,
Besides trying a blank bitfile, another interesting check would be to verify the usage in the compilation log. That may show whether or not there is a discrepancy with how the resource utilization is being reported.
Will
(636 Views)
Dear colleagues,
Thank you for your replies. I've done both things:
1) Compiling a blank vi: Final device utilization is = 120/6822 total slices, 306/54576 slice registers, 246/27288 slice LUTs... but 0/116 Block RAMs (and 0/58 DSP48s).
2) Reading through the xilinx log, I find these lines:
INFO: [Designutils 20-277] Completed resource estimation on toplevel_gen - Slices: 4163, LUTs: 11324, Flops: 8185, BRAMs: 4, DSP48s: 6
Design Summary:
Specific Feature Utilization:
  Number of RAMB16BWERs:                         2 out of     116    1%
  Number of RAMB8BWERs:                          2 out of     232    1%
Device Utilization Summary:
These figures match the gross total of 3 given by the "Display Compilation Results" window, as long as two 8-kb blocks count as one 16-kb block, as seems to be the case.
Having said all that... I may have found an answer. I forgot to mention that I also have three "Look-up Table 1D" items in the FPGA diagram. In their config menus they confess that they will take 4kB=1k*16b; 128B; 128B.
Do you know how such "Look-up Table 1D" items are implemented? I assumed they were implemented as fabric LUTs, but perhaps the name has misled me, and are actually implemented as BRAMs instead? This could unveil the mystery!
Biscay.
(622 Views)
Sorry, when I said 4kB=1k*16b I obviously meant 4kB=1k*32b. Biscay.
(619 Views)
Accepted by topic author biscay
06-19-2018 08:38 AM
Hi biscay,
I'm assuming you're referring to the Look-Up Table 1D Express VI. If that's correct, that VI does typically get implemented using BlockRAM resources. From the Help for that VI:
@biscay The main FPGA resources used for implementation of the Look-Up Table 1D are block memories, which Xilinx literature describes as block RAMs or BRAMs.
If you explicitly are looking for an implementation that uses LUTs in LabVIEW, I would recommend one of the following:
  1. Use a Memory Item with the Implementation set explicitly to LUTs.
  2. Use one of the array constant patterns for optimizing array constant memory usage that will resolve to a LUT implementation.
I believe the Express VI is referring to Look-Up Table in terms of the data structure rather than the physical FPGA resource type.
Charlie J.
(611 Views)
Charlie, good point! Definitely, it makes much sense. And sorry for having missed the "Look-Up Table 1D Express VI" help entry, which is crystal clear.
Biscay.
(605 Views)
Reply
