Dear All:
I found I have to deal with 128 channel data comes at about 50Hz or so, I already know the signal itself changes relatively slow, I would like to use 9651 to capture and store as much data as possible, the SDCARD or USB is not connected at current product, so I have to think about algorithm, which is not my area...
So I try to find information about waveform compression, but doesn't find much of useful information about it, does any one have any idea about it?
There a many question in my mind, like:
1. Say that there is a good algorithm around, can it easily port to RT linux?
2. Is Zynq powerful enough to deal that amount of data realtime?
3. What to expect on the compression rate? would it reach 10:1? or maybe only about 1.2~1.5:1?
4. Is it wise to consider audio compression algorithm like mp3,ogg, or the lossless ones, like flac?
5. I even considered the ADPCM, seems it can save some amount of space and can easily use FPGA to coding. are there any downside about ADPCM?
Thanks~
