I'm using SOM 9651 with a external clock, the program used to working until I add a derived clock from external clock.
Is it not supported by LabVIEW FPGA or SOM 9651? or maybe there is something I can do to fix this problem.
I made two simple SCTL with only the external clock driven loop, and a external derived clock driven loop, the issue is the same, can't finish compliation so there should not be something with my code, it might be some limitation with the SOM platform?
The external clock is 100M, and the added derived clock is 25M.
Thanks, below is the error information.
LabVIEW FPGA: The compilation failed due to a Xilinx error.
Details:
ERROR: [DRC 23-20] Rule violation (PDCN-1568) BUFGCTRL_S_pins_both_connected_to_gnd - For cell window/Bufgce0/GenBufgCtrl.BUFGCTRLx placed at site BUFGCTRL_X0Y20 both S0 and S1 pins are tied to GROUND. Selection of an input clock requires a "select" pair (S0 and CE0, or S1 and CE1) to be asserted High. If either S or CE is not asserted High the desired input will not be selected. Please modify your design.
