01-09-2017 11:47 AM - edited 01-09-2017 01:43 PM
I had a quick question about the CAN ports on the sbRIO-9607. The CAN0 port is implemented and usable without a FPGA bitfile correct?
When I compare to the clip wizard for the 9651 I see you need to implement both CAN ports there so I assume for the 9607 since only CAN1 port is listed then CAN0 can be used without compiling a bitfile. We've tried with and without the bitfile running but I'm still getting a bus off error.
We've created a CAN device that we can talk to using a X-NET usb card but when we swap for the the embedded CAN driver to see any of the bus traffic we get a Bus Off error.
We've ordered the NI cable to try and loopback between X-NET and the CAN0 port next but just wanted to double check its not something simple.
01-10-2017 02:49 PM
Ok so looking at the block diagram here,
http://www.ni.com/pdf/manuals/375463a.pdf
The can port is routed through the FPGA so I need a bitfile running (or the default bitfile should be on?)
We scoped the CANL and CANH lines and we see traffic data but it doesn't seem the API is calling into it correctly.
01-10-2017 02:52 PM
CAN0 shouldn't require a compiled/deployed bitfile. Generally speaking, the only peripherals that require that are ones that you enable through the sbRIO CLIP Generator.
Eric
01-10-2017 02:59 PM - edited 01-10-2017 03:51 PM
Thats what I thought. The PCB silk screen shows CAN1 on the the IDC10 header but I thought CAN1 (which is enabled through the CLIP Generator) was tied off the SEARay connector. Either way when running a bitfile with the CAN1 enabled our CAN bus reports BUS OFF. We'll probably wait till the IDC10 to DB9 cable comes in before pushing further.
It'd be nice if there was a table in the manual for how many CAN ports are available and how to enable them. Hindsight 20/20.
01-10-2017 04:26 PM
It looks like the silkscreen is mislabeled. The documentation confirms the onboard port should be CAN0 and the expandable port is CAN1. I'll make sure R&D is aware.
We actually do have something the reference the available ports. It's in the specifications document and references the number of ports and whether they are onboard or expandable via the RMC (page 4 for CAN).
http://www.ni.com/pdf/manuals/375277a.pdf
-Eric
01-17-2017 01:43 PM - edited 01-17-2017 01:44 PM
Alright, Good news!
Loopback between the usb can device and the sbrio was successful.
It seems like the connector wasn't quite fitting with the header on the sbRIO. We were able to remove the pins from the connector and everything started working at a lower baud rate. Once we tweaked a few timing parameters with our custom board we were able to see the bus traffic with the sbRIO at 1 Mbps.
01-20-2017 09:50 AM
To clarify Eric's statement, there is always a bitfile downloaded in the FPGA fabric (a Default Bitfile) which includes CAN0 support regardless of if a user has a LabVIEW FPGA bitfile downloaded or not; therefore, CAN0 will always be present.
01-20-2017 09:55 AM
Tannerite,
Thanks for the clarification. I had thought as much when comparing project differences between the 9651 and the 9607. Glad to see everything was working correctly and just some timing tweaks on our hardware.
09-02-2021 08:45 PM
myfriends
CAN you tell me how to develop the second CAN port? , I designed a PCB board according to RMC Design Guide, and then the PCB board was connected to 9694. This is my idea of developing the second CAN interface, but I don't know how to implement it in software
thanks
