Hardware Developers Community - NI sbRIO & SOM
Reply
Highlighted
Solved! Go to solution
9683 RMC card: current sourcing capabilities of LVTTL 3.3V supply and DIO pins
I am attaching another custom made board on top of the 9683 RMC.
There, I need to feed some 3.3-Volt circuitry, which will demand about 24-30 mA.
I am tempted to draw that current from pins 1 and 3 of the 60-pin LVTTL connector... however, if these pins behave like the other pins, because the manuals say that only a 3-mAmp supply is guaranteed per pin, I would get just 6 mA.
So, how could I manage to get from 24 to 30 mA? Does it make sense to configure other DIO pins as outputs, and set them high, e.g. all eight DIO7:0 simultaneously, to source 24 mA?
Thank you!
Biscay.
(1,028 Views)
Re: 9683 RMC card: current sourcing capabilities of LVTTL 3.3V supply and DIO pins
Pins 1 and 3 of the 60-pin LVTTL connector are not limited by the 3 mA spec of the signal pins. These +3.3V pins are connected to the FPGA_VIO rail on the sbRIO, which can supply up to .33 A.
Will
(1,012 Views)
Will,
Thank you for your reply!
However, out of those 330mA that the FPGA_VIO rail can supply, how many are consumed on the RMC, and, then, how many are left for "other uses" such as mine?
Biscay.
(997 Views)
Accepted by topic author biscay
02-01-2018 02:27 PM
The RMC itself will consume approximately ~71mA typical or ~228mA max from that rail. So you should be fine pulling an additional 30 mA.
(985 Views)
Great! Thanks again. Biscay.
PS: I may have missed all that information in the manuals, but in case I didn't... I think it's a good idea to provide these figures in the datasheets etc.
(981 Views)
Reply
