General
Software expires in 23 days
I have not been able to activate my FRC driver station software properly.  Every time I open it I get the notification.  It says its the vision development module which I don't know that I even need.  We are not using Labview, just the drivers station.  I just don't want the software to quit working just before competition!
(1,535 Views)
Accepted by topic author cantieny
You should not have a problem if that component expires. I assume you had installed LabVIEW for FRC 2022 before.
You should be able to use the NI serial number assigned to your team if you choose to use the Vision Development Module for programming your 2023 robot if you install LabVIEW for FRC 2023.
Cheers,
(1,506 Views)
Thanks Oscar!
(1,496 Views)
