I am working with an FRC team to make a connector board that fits onto a RoboRIO and have been using the dimensions and connector locations as per page 22 of the RoboRIO manual.
Our prototype works well, however all of the PWM connectors on the RIO are offset from our board by around 0.5 to 1.0 mm, where all of the other connectors line up perfectly. There appears to be an offset error in the manual on all the dimension for this row of connectors. (note that the connectors with measurements "54.40mm" and "74.70mm" have an additional error, but this was easy to see and work around).
I can make an estimated correction which should get us out of trouble, but I would prefer to get an accurate distance if one is available and get the manual corrected for others in future.
Is anyone at NI able to provide the correct measurements for the locations of these connectors?
